1 - 3 of 3 Posts
I HAVE A 2009 BURGMAN 650 AND IT WILL NOT SHIFT OUT OF FIRST GEAR. CAN ANYONE TELL WE WHERE TO START LOOKING FOR THIS PROBLEM. I WAS TOLD THERE ARE 4-5 SOLINOIDS AND THAT COULD BE THE PROBLEM. THANKS
The interlock switch for the Center Stand will cause this look and see if it is stuck/bent /broken
Yes, the center stand switch is the first thing to check. If the plunger is stuck in just pull it out. If that doesn't do it follow the wire up to the plug and unplug it.
1 - 3 of 3 Posts
