Over the summer I got some work done on my bike that I thought would be ground ball type work for a bike mechanic. I had my tires changed and my front brakes. A mile or two after picking up my bike I noticed that the front brakes sticking. Towed it back to this assshole's shop and he ended up "rebuilding" both the front and rear calipers and then realized I needed a new front rotor because it was warped from the brake pads sticking.
Anyway, I've been using the bike every now and then after this repair and it seemed to be working OK for the most part (besides seeming to require more RPM than before to reach the same speed...which may or may not be in my head) but yesterday mid ride while using my rear brakes it went pretty much totally slack on me. The rear brakes aren't sticking though. After pumping the brakes a bit the slack gave way to more resistance as I applied the brakes but the rear brakes are not working at all.
What do you guys suspect is the problem? What is the best course of action? Can anyone recommend a GOOD mechanic in the STATEN ISAND NY (or surrounding area) Thanks in advance for any feedback
