1 - 4 of 4 Posts
Issue...the bike will stop running when the temperature hand reaches the midway between cold and hot.
The fuel pump will still prime. I disconnected the line at the throttle body to ensure fuel was pumping and getting plenty of fuel to the throttle body.
The bike will then not restart until the temperature hand reaches the cold mark again. It will idle and run fine until the hand reaches the halfway mark again and then die out as if turning off the key.
Any help is greatly appreciated.
Hi Stunna, this sounds a puzzle. Is there a fault code showing on the dash when this happens? If so, what is it? Does the engine cut out when you are riding or just when the bike is idling?
No fault code showing. The bike will cut out whether riding or idling when the temp hand reaches the halfway mark.
Sounds like the Protection System kicking In, To Protect from Engine Damage,
Check your Cooling Levels ,for Fluid Blockage
Elliott,
1 - 4 of 4 Posts
