You may be right.
Problem is, there isn't really anywhere "up" to go to.
I'm open to suggestions.
The only "up" option I see is if you place it outside the bodywork OR inside the trunk - neither of which sound good.
Per that thread I linked above, one user GK13 just added an Auto PCV valve to the end of the small existing crankcase port hose (+ blocking Airbox port) and said "it solved my oil usage issue".
So, I'm modding my plan, by adding an Auto PCV valve immediately below Breather Filter, in end of longer PCV hose.
Should have same / similar effect that GK13 describes.
Test, ongoing....
TY - David
[/QUOTE
Hey y'all:
Ok, I'm almost ready to road test this.
Tupperware is still off but the PCV re-route is finished.
Here's my YouTube overview:
All comments & feedback welcomed -
TY - David
Thanks for the video, David. I'm gonna wait to see how the oil consumption is affected before I go to modding. May I suggest running the numbers on oil consumption how you have it set up now. Then add the PCV valve. On a side note. Your frame looks like you repainted it? I have a bunch of surface corrosion on mine. I may need to address it.
