There has been much discussion about the new 650 overdrive feature on the new 2005 model, but I have not seen any information about it on this site from anyone who actually has one and tried it out. I received some information from a new 650 rider who has tried it out and gave this account. Apparently the only way you can be sure that you are in overdrive is in the manual mode, where there is an overdrive indicator to the right of the 5th gear indictor on the dash. It apparently drops the engine RPMs about 500-800 below the 5th gear level. According to Suzuki reps the final drive ratio drops from .9 in 5th geear to .8 in overdrive.
Also according to the Suzuki rep the same final gear is also in the automatic mode, it is just that you do not get an indication that you are in overdrive when you are running in automatic (probably not ever reached in the power automatic mode). That would make sense, since the manual mode just selects predetermined settings already available in the automatic mode range. Also according to the new 2005 owner there is a milage indicator for each of two trip meters, so you could then keep track of your milage for your current tank of gas and for a trip as well.
It seems to me that these changes, as well as the ambient tempature gage and the cosmetic changes are significant enough that they would be pointed out in the official Suzuki posting for their 2005 model. However, on their site the only thing listed under "New Features" is an emissions improvement available on the California models. Why would that be???
