I prefer clean air without buffering around my head. Will the S shorty fit my standard since they should be the same model design? If so, were can I find a S model shorty
or a similar one?
Yes it will bolt right on. As for where you can get one, unless you can find a used one then your only option is to order it from a Suzuki dealer or one of the online retailers. The part number is 94611-14GS1. Put that number into Google and do a search and you can lots of sources.
Be sure you do not order part number 94611-14G10. That is the standard screen.
Another cheaper option is to just cut your stock screen off to the length you want. It's easy to cut them.
I'm assuming here you are talking about the 2003-2006 400 as you don't specify which model bike you have but there is no sport screen for the 650 that I know of.
White Burgman 650 standard
Clearview had one but don't know if they still do - contact customer service and see.
They will build it if you want.
Drop the bars a bit...stick tires ....hey a real sleeper.
Thank you for the number and response. The 400, yes the 400, came with a very large GIVI. I am glad to have that in the mornings under 40 degrees. And it has a very bulbous shape that doesn't lay close to the dashboard. So for cold days I can deal with the buffeting. But when it warms up, I really want that shorty. Thanks again. ...ride safely!
