21 - 21 of 21 Posts
This could also not be an ignition issue.
  • If the battery voltage is low the bike will run bad.
  • If the wire connectors under the battery are corroded the bike will run bad.
  • If the 2003 Ignition Switch was not replaced in the RECALL, the bike will run bad.
All 2003 Burgman 650's had a Service Recall for the ignition switch. It was a free recall. But if your dealer did not get the recall it may not have been done. The local Suzuki work shop should be able to run your Vehicle Identification number.
21 - 21 of 21 Posts
