1 - 7 of 7 Posts
Kello,
I am looking a way to get 12v under the seat, but of course under the key too.:confused:
Is there some connector or fuse to use? I nee to power a gps unit only when the key is in ignition position.
thanks
ciao
for GPS Power on by Key take the power from the back of the power socket in the glove box
+1........this the best way of doing it. NOTE: if the GPS cable is not already fitted with a fuse, make sure you wire in an inline 1A fuse, otherwise if things go wrong the GPS will be subject to the power socket's full 10A.
There's also the wire for the license plate lamp as well that runs along the front of the trunk box between it and the fuel tank if you were considering an outlet in the trunk for device charging applications. Though I'd use that just for a relay to switch a line from the batt since it's close.
Thank you guys, that's what I was looking for. I need an extra power source under the seat to place an electronic device on the trunk box.
I will check on the wire diagram to find the right wire.
ciao :)
fausto
1 - 7 of 7 Posts
