I came home tonight and decided I would start and run my '09 that's been sitting in the garage since I put my '03 back together and I've been riding that. Turn the key on, pull a lever and push the starter button. It cranks a little slow and doesn't start. Ok put the battery charger on it for a while and try again, nope.
Checked and no F1 light, hmmm. Do a battery disconnect, nope. Smells like fuel from the exhaust so maybe I flooded it opening the throttle while cranking? OK pull the panel to get at the fuel pump connector and unplug it, crank the engine a few times to hopefully clear the flooding, nope. Grrr, ok now what? Pull the engine cover and radiator shield, take the left bolt out of the radiator, swing it out and clamp it to the front brake rotor, and pull the coils/spark plugs. The spark plugs are not wet with fuel, carboned up, and the gap is ok. Pulled the fuel pump connector, plugged the coils in loose with spark plugs and cranked it over. Well I have spark, then it dawns on me that when I stored the bike up on the pedestal there wasn't much fuel in it and I had run it a few times off/on. I look at the fuel gauge and both the last segment and pump icon are flashing. As I pull the fuel cap off I hear a sucking not pressure sound, hmm. Well I took my NATO gas can down to the local station and put 2 gallons in it, then came back home to put in the '09. I put the spark plugs/coils back on, plugged in the fuel pump, pushed the button and she fired the first time. Go figure, lol.
Oh and then after that I tore apart a toaster I found that was going to be thrown out at work (was kinda dirty with stuff melted on the grilles like a BBQ), cleaned all the bits, reassembled it and voila I have a usable toaster.
